Farmall Tractors Discussion Board
Re: Re: Re: Overhauling a Farmall H - How hard is it?
Posted by RKS on May 01, 1999 at 19:59:28:
In Reply to: Re: Re: Overhauling a Farmall H - How hard is it? posted by Greg M on May 01, 1999 at 18:48:30:
change the oil regularly, now if you haven't lately or you just bought it - use a good 30 wt, not multigrade, and use also one or two cans of STP oil treatment. The early smoke may be rings or oil leaking down worn valve guides. If it is rings, then the improved viscosity of the oil/STP will slow that down some. Actually, when the engine gets to operating temperature, the small amount of oil that leaks from the valve guides is burned more completely in the combustion stroke, and you see less visible evidence (blue smoke). Bad enough rings or bad enough valve guide leaks, - - and you would always see blue. I'd bet that if you work the old H hard under load for an hour or so, you'll probably see some oil consumption. That's ok, and it's up to you when to do something about it, but if it doesn't use more than a quart every 5-10 hours or so, I wouldn't worry about it.
Post a Followup
: Re: Re: Re: Re: Overhauling a Farmall H - How hard is it?
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
