Farmall Tractors Discussion Board
Re: frozen H hydraulic pump
Posted by Dick Davis on February 02, 1999 at 04:39:21:
In Reply to: frozen H hydraulic pump posted by JOE on February 01, 1999 at 18:21:28:
If you don't have a need to use the hydralic pump just pull out the two bolts and slide off the sleeve that connects the shaft between the rear of the pump and the front of the transmission. This area can be reached from under the tractor, you might have to remove a dust cover, but it is pretty straight forward. If you need the hydralics only four bolts and the plumbing lines hold the pump/reservior in the tractor. Once you have the reservoir out a visual inspection can often determine why it is locked up. Some times the linkage is broken. Take it apart and see if you can determine the problem if you can't figure it out you can always purchase a used or rebuilt pump and or pump/reservoir. I ran a "Wanted H Hyd pump"ad in the classified and received 8 responses. Prices varied from a rebuilt for $220 to $20 for a used but guaranteed. "You pull it and if it doesn't work you can pull another!" Several around $ 100.
Good Luck Dick
Post a Followup
: Re: Re: frozen H hydraulic pump
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
