Posted by jm. on October 04, 2012 at 16:14:18 from (99.196.0.56):
In Reply to: TD15C engine swap. posted by jeff Lowery on October 02, 2012 at 10:44:49:
Jeff; Several ways ,some folks lean the hard nose over with the radiator in it. If the tractor is very old the pins are hard to pull. I always thought it was faster to remove the fiberglass dash shroud then the 2 boldts on each side of the dash frame. Ten you will have celar acess to the mount boldts. Absolutely not necessary to pull the torque, Simply go all the around the torque mount boldts, remove them you will find that the torque will sit on the mounts and may tilt back just a little. Removbe the front engine FAN, kinda hard to get to the boldts. lay the fan up against the radiator. Remove the front two mount boldts slide the engine foward 4 inches and lift out. Flip side if you want to remove with torque just pull the rear mounts, remove the pumps,they will slide back with hoses still attached , remove the drive line and lift the entire engine and torque. Not reall much diffrence more of just what you prefer. NO internal torque boldts, recessed star gear drive / E-mail open if you need more info.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
