Posted by NCWayne on September 24, 2012 at 21:47:39 from (69.40.232.132):
In Reply to: D3 engine noise posted by Tann1 on September 24, 2012 at 17:59:58:
You say you hear a clunck or 'knock' before it cranks....have you pulled the starter to insure the bendix isn't buggered up and the sound your hearing is it engaging in the flywheel starter ring? I have also seen starters that would hang up when starting, if the teeth were screwed up. When that happened, instead of kicking out like they were supposed to, they would motor around (((until something blew up or the engine was stopped and they released until the next time,)) and would cause all sorts of odd noises.
On the opposite end of the spectrum. I had one in a CAT scraper years ago that made no noise at all until you wound the engine up to a high RPM, and then it sounded like some sort of jet turbine. When pulled the starter was so hot I had to use welding gloves just to get it on the ground as it was too hot to even think about handling otherwise.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
