| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: D3 engine noise
[Return to Forum]
| Author |
[Modern View]
| Tann1
09-24-2012 17:59:58
72.171.0.142
Recently purchased a 79 cat d3. Engine was overhauled 23hrs ago runs great. I've noticed when cranking before it fires u hear a loud deep clunk or "knock" . U can listen and hear it when running but at that point it doesn't stand out just sounds lika diesel. Noise sounds more lower and rear just not sure what it is. Deffinately not a rod or it would have flung through the block by now being that loud and holds 50lbs oil pressure and once warm almost no blowy. Is this a normal noise for a 3204? Any help is appreciated thanks |
| Tann1
09-30-2012 14:14:00
67.142.130.29
Re: D3 engine noise in reply to Tann1, 09-24-2012 17:59:58
| I have pulled starter and spun flywheel all way around noticed no bured up or damaged spots just normal wear. Also starter is fairly new replaced by last owner when it "would barely crank over" just a deep knock almost like cracked flywheel or loose converter bolt sound. But those checked out good as well least what I could get visual of. Trying to get all the little kinks Outta this thing is taking longer than expected as usual haha. Get to take track off next weekend to rebuild blown tensioner. So excited bout that. I feel backhoe will be very handy for handling that. |
| Brian Allen
09-30-2012 14:03:02
142.169.215.28
| As Old Magnet suggested, you need to pull the starter to check for damaged teeth on the ring gear, I suggest doing it before the starter destroys itself. A file should remove any damaged areas on the ring gear teeth that cause the starter to ride up (usually in one spot where the starter first engages the ring gear).
Brian |
| tann1
09-25-2012 04:15:11
166.137.88.27
| The noise is when the engine is cranking but before it actually fires up. Not at initial starter engagement. Notice it more when engine is cold simply because it cranks longer before it fires. I would guess its one knock per engine revolution. Thanks |
| NCWayne
09-24-2012 21:47:39
69.40.232.132
| | You say you hear a clunck or 'knock' before it cranks....have you pulled the starter to insure the bendix isn't buggered up and the sound your hearing is it engaging in the flywheel starter ring? I have also seen starters that would hang up when starting, if the teeth were screwed up. When that happened, instead of kicking out like they were supposed to, they would motor around (((until something blew up or the engine was stopped and they released until the next time,)) and would cause all sorts of odd noises. On the opposite end of the spectrum. I had one in a CAT scraper years ago that made no noise at all until you wound the engine up to a high RPM, and then it sounded like some sort of jet turbine. When pulled the starter was so hot I had to use welding gloves just to get it on the ground as it was too hot to even think about handling otherwise. Good luck and let us know what you find. |
| Tann1
09-24-2012 18:01:30
72.171.0.142
| Also no difference when hot or cold. Thanks |
| Old Magnet
09-25-2012 07:32:21
108.93.152.109
Re: D3 engine noise in reply to Tann1, 09-24-2012 18:01:30
| I'd be checking for buggered up teeth on the flywheel ring gear. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
