Sure...You bet it can.. My test will only show the lowest relief valve setting.. There are a gammit of relief valve tests..There are circuit relief valves and main reliefs that need to be set. If you know someone that can read your flow/pressure readings with a flowmeter, that would eliminate a worn pump..Usually relief valves don't change unless a spring looses it's tension. Then even after resetting the relief it can return to a lower setting due to a spring weakening..
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
