| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: JD 690B-how to check and set relief valves
[Return to Forum]
| Author |
[Modern View]
| jacks
09-01-2012 16:08:31
71.246.155.40
I need to check my relief valve settings. It has gradually lost some lifting power over the years. The procedure is not covered in the factory service manual. What sequence should be followed? Thanks, jack |
[Reply] [No Email] | |
| Roy Suomi
09-02-2012 05:50:43
76.190.200.252
Re: JD 690B-how to check and set relief valves in reply to jacks, 09-01-2012 16:08:31
| My 690-B manual has the procedure for testing pressures, I don't know why yours doesn't.It is a long drawn out affair..If you follow the procedure by the book, it should work out right.. |
| Roy Suomi
09-01-2012 20:41:06
76.190.200.252
| On the boom cylinder plumbing , right at the cylinder tubes, you will find "Tees".. If you plumb in a guage at the tees and dead head the oil circuit , the reading you will get is the lowest relief valve setting of the combined flow oil circuits - OR - the fact that the pump is worn to the extent that it won't produce enough pressure to pop off the relief valves.. |
| jacks
09-02-2012 04:16:14
71.246.155.40
Re: JD 690B-how to check and set relief valves in reply to Roy Suomi, 09-01-2012 20:41:06
| Thanks Roy and John. With the boom lift cylinder deadheaded, is it only the relief valve for that circuit that determines the relief pressure? Could any one relief valve that is relieving at too low of a pressure effect all of the circuits? |
| Roy Suomi
09-02-2012 05:46:16
76.190.200.252
Re: JD 690B-how to check and set relief valves in reply to jacks, 09-02-2012 04:16:14
| Sure...You bet it can.. My test will only show the lowest relief valve setting.. There are a gammit of relief valve tests..There are circuit relief valves and main reliefs that need to be set. If you know someone that can read your flow/pressure readings with a flowmeter, that would eliminate a worn pump..Usually relief valves don't change unless a spring looses it's tension. Then even after resetting the relief it can return to a lower setting due to a spring weakening.. |
| J. Schwiebert
09-01-2012 19:32:17
209.143.28.10
| Have you put a gauge in the circuit and checked to see what pressure you have now?Can you "deadhead" a cylinder and blow the relief valve? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
