Posted by Old Magnet on August 16, 2012 at 19:50:55 from (76.254.44.19):
In Reply to: D6 pony motor posted by chickensoup on August 15, 2012 at 14:33:49:
The washer butts up against the bearing to control the thrust on one direction. The crankshaft butts up against the other bearing to control the thrust in the other direction
If the crankshaft thrust face is in good condition the bearing can be moved and the dowel pin and lube holes can be redrilled using the housing as a guide. Drill 15/64 and ream to 0,249-0.250 for the dowel.
Thrust should be 0.010 to 0.016 Max allowable is 0.025.
Another option is to make an all new bearing out of T6 aluminum that fits the conditions. Crankshafts can also be built up to restore original clearances and fit original bearing specs.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
