if THE FORWARD CLUTCH PAC IS TOAST I feel sorry for you . Years back i got coned into working on a 580 B with the same problem . First off it was no picnic splitting it as i am not set up for working on Ind. When i got it apart and tore down the forward clutch pac was history . Having no contacts other then The Case dealer i am stuck with them . Come to find out that what i need to fix this thing are no longer available from case and had to get a whole unit that WOULD fit with some mods to it for use on a shuttle with out PTO . . And here was the kicker to all this , they did not know what part numbers were they needed to get to put in the PTO unit to plug the thru hole to block the oil flow where the seals went on the Thru PTo shaft as they had to be PLUGGED . .Anyway that unit cost back then over 4300 bucks plus all the rest of the pieces and parts . The guy that owned the machine had almost as much as he paid for it in repairs . I learned one thing , STICK WITH a gear drive as a clutch is a lot less money.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
