I have several 1000 case crawlers. The 1150 uses the same transmission , but the charge pumps are different. It sounds like you are loosing the pilot bearing or bushing inside the torque converter that carries the output shaft,this permits the two halves of the torque converter to rub together . Check to see if your metal particles are steel or aluminum.If aluminum , it will be the torque converter. If steel ,it would have to be something serious in the trans which rarely happens.
The fact that it runs and quits , says that the suction filter for the trans is full of metal,and when you shut it down the metal falls down out of the filter , when you run it picks it up again.
Had that happen on my dozer many years ago, when it lost the bushing in the converter. In the old ones the bushing is NSS , so I made one , been running for 35 years since.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
