Posted by G B Johnson on May 25, 2012 at 19:01:41 from (4.153.93.56):
I have an oil leak on the engine block between the injector pump and the govenor, behind the booster fuel pump. The oil is not comming from the booster pump. The oil drips onto the motor support below. I have an oil leak around the throttle control shaft but I believe there is more oil comming from somewhere else. To replace the seal around the throttle shaft I need to remove the plate on the govenor held on by six bolts. Will things fly apart if I remove the plate to replace the seal? Any ideas where the other oil may be comming from? Thanks, G B
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
