It won't run 180 degrees off. The fitting with the ball and spring is the housing-pressure-regulator-valve. Not just a fuel check valve. New one costs $7. It maintains internal housing pressure at around 5-6 PSI. Running without it would make the auto timing advance cut in a little earlier. I doubt it's your problem. But . . have you checked the timing advance? To do so, you need a $10 plastic timing window. Maybe you can borrow from a Deere mechanic?
Today's Featured Article - Search For Spares - by Anthony West (UK). Following on from the aquisition of the old Fordson F, I was very much in need of spares. As a novice though I didn't appreciate the fact that there were so many Fordson tractors made, that all the other makes seem rare by comparison. As far as I was aware a fordson was a fordson and it was only through trial an
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
