mikefromcny
Long story short, My case 585c forklift started running rough after the gov. dampening ring started to fail, pulled the check valve at the top of the housing, made no difference, other then it wouldnt stall once in a while.
Pulled the db pump, upgraded to the solid part, replaced o rings etc.
Runs perfect above 1/4 throttle. Still runs a little rough from idle up to 1/4 throttle. Anything I should check, or anything I could have over looked? Pump was packed full of the the old dampening ring, Made sure I got everything before reassembly.
I can live with it how it is now, but its aggravating after all the work it took to do the pump.
John Demaris, Could you send me your email? Tried to send you one earlier this week but I might of had your old one. [email protected] Thank you.
