I was having trouble running an auger because, as it turns out, the pump pressure was way way too low. I got some good advice from NCWayne and set up a test instrument. Then I put in a new pump and it was like a double dose of viagra. The middle pedal runs the outer spool on the second valve, and I would bet that all you have to do is adjust your linkage at one or both ends so that you get enough movement when you move the pedal both ways. But I suppose you're not running hydraulics from the operators position so the splitter probably has its own valve. That means you need a direct line to the splitter valve, which you could feed with the auxiliary hydraulics and then just block the pedal one way or the other.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
