There could be several reasons why it came loose in the first place,not tightened to the right torque,overtightened and cracked the hub,hub not a snug fit on the shaft,have a look when you get it off,usually when pulleys comes loose means that they are not a snug fit on the shaft,use a torque wrench to tighten the nut rather than an impact wrench,impact wrenches are ok for pad bolts and wheel nuts but not for engine parts which should be tightened by hand. AJ
Today's Featured Article - Tractor Traction - by Chris Pratt. Our first bout with traction problems came when cultivatin with our Massey-Harris Pony. Up till then, this tractor had been running a corn grinder and pulling a trailer. It had new unfilled rear tires and no wheel weights. The garden was already sprouting when we hooked up the mid-mount shovel cultivators to the Pony. The seed bed was soft enough that the rear end would spin and slowly work its way to the downhill side of the gardens slight incline. From this, we learned our lesson sinc
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
