Anonymous-0
Last year the big nut that holds the pulley on the water pump of my 931B came loose. I took the water pump off and tightened the nut but didn't use any loctite. It was good for a while but I noticed that it's loose again. Should loctite solve the problem or should I just put a new water pump on? The water pump only has about 1000 hours but is a jobber pump. Would a wobbling pulley make any difference in charging the battery? The amp gauge doesn't hardly move, even after starting. I boosted it today and it still didn't move much. I'm also wondering if the battery could be going bad and that's what's causing the charging problem. The battery is about 5 years old but was a reconditoned battery. It's a pain to replace the battery but I want to make sure that it's the problem. It's an 8D battery and I paid $80 for it. A new battery was at least double the price so I'm not complaining about getting 5 years out of it. Thanks. Dave
