Cat D3 and more commonly the 931 loader series. I have a 931B with a 14 ft. quick detach hoe on the back. It's not real fast at anything but does lots of different jobs. The hoe has pretty good digging power and decent speed. Not too hard to use but takes a lot of experience to make the job look like you want it to. Cat, Case, JD all had hoes available for their smaller crawlers. I've had to do a bunch of work on mine but it's pretty reliable now and has a good transmission. The JD's apparently had tranny issues. The Cat hoes use the same seat as the loader which is a little awkward crawling over but I think is better than the JD that uses a seperate seat. The JD would give better visibility in a deep hole but you have climb on and off to move the machine. If you're in soft ground on the Cat, you can pull/push yourself out with the hoe and transmission. The JD you'd need someone else to help you. Dave
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
