When I charge my 450, I fill the 2" suction hose to the charge pump (without the engine running). I then quickly hook it to the intake screen and start the machine.
I suspect that you are drawing too much air when you run the engine, pour in oil and then try to connect the hose.
You should also only have to do this once. The machine should not loose oil in the suction hose when the machine is off. If it does, that suggests a leaky charge pump. Fortunately a charge pump is (relatively) inexpensive.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
