case 450 charge pump
tmoore45acp
03-31-2008 16:25:21
my case 450 will not pull-have changed suction hoses and all filters-should charge pump have suction when you put your hand over suction side of pump? have no torque converter pressure
dieselpaul
03-31-2008 22:59:30
 Re: case 450 charge pump in reply to tmoore45acp, 03-31-2008 16:25:21
I used to drain fluid & service filters on these units, fire back up & have no trouble with pump picking up. there is a pipe elbow @ suction side of pump on some models that would loosen @ suck air, [o-ring] as others said,shaft seal.
george md
03-31-2008 20:58:43
Before you buy a new pump , invest a few dollars in the shaft seal in the pump , it is a disease of charge pumps.
george
marlowe
03-31-2008 16:35:35
with oil in it you will dry not a lot
tmoore45acp
03-31-2008 17:51:10
 Re: case 450 charge pump in reply to marlowe, 03-31-2008 16:35:35
pump must be full of oil in order to pump or just residuel oil?
tmoore45acp
03-31-2008 17:56:22
 Re: case 450 charge pump in reply to tmoore45acp, 03-31-2008 17:51:10
if i take suc. hose off and pour trans fluid into pump i will get about 25 lbs of torgue conv. press as long as i am pouring trans fluid in hose when i stop and quickly reconnect hose press goes back to zero-do i have a bad charge pump?
John Van Valkenburgh
03-31-2008 18:17:10
 Re: case 450 charge pump in reply to tmoore45acp, 03-31-2008 17:56:22
When I charge my 450, I fill the 2" suction hose to the charge pump (without the engine running). I then quickly hook it to the intake screen and start the machine.
I suspect that you are drawing too much air when you run the engine, pour in oil and then try to connect the hose.
You should also only have to do this once. The machine should not loose oil in the suction hose when the machine is off. If it does, that suggests a leaky charge pump. Fortunately a charge pump is (relatively) inexpensive.
Best of luck,
John 1968 Case 450
tmoore45acp
04-01-2008 04:20:29
 Re: case 450 charge pump in reply to John Van Valkenburgh, 03-31-2008 18:17:10
i have tried that and that does not work-
tmoore45acp
04-01-2008 06:40:04
 Re: case 450 charge pump in reply to tmoore45acp, 04-01-2008 04:20:29
my local case dealer wants $900.00 + for a charge pump-after market pump 280.00 but is aftermarket pump any good?
