Posted by Kyle Fenstermaker on March 11, 2008 at 07:04:16 from (143.79.13.6):
In Reply to: Bad injectors? posted by 135 Fan on March 06, 2008 at 17:07:03:
Check the return line back to the tank. There is a blockage somewhere from injection pump to the tank causing too much back pressure on the injection pump. That will cause the smoking and lack of RPMs. Usually its the check valve in the injection pump going back to the tank. One way to see is remove the fitting from the injection pump and start it up, kind of hold your hand over the threaded hole so you don't get sprayed in the face. The smoking should stop and it should have a better throttle response-if so your problem is from the check valve to the tank blockage.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
