Posted by jdemaris on May 06, 2014 at 18:19:52 from (70.194.11.11):
In Reply to: JD 350B power posted by john jenner on May 06, 2014 at 13:20:56:
I'd suspect the steering clutches over the reverser - but it could be either. I think under the seat on top of the rear of the transmission - there is a plate you can removes so you can see the top of the ring-gear (that drives both final drives). If you can seed your ring gear - the thing to do is make it slip while in gear and see if that ring is turning or not. If it's turning- both your steering clutches are shot. If it's NOT turning - then it's your reverser that's slipping. You can also put a gauge into the control valve of the reverser and check pressure. Near where the clutch pedal linkage hooks to it - there are two 1/8" pipe plugs. One is lube/release pressure and the other is clutch pressure. Lube should be 15-25 PSI and clutch pressure around 120 PSI. If it's under 100 PSI you can assume the reverser is slipping. A grease gun hose with a 200 PSI gauge screwed onto it will work for the test.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
