john jenner
New User
Bought a JD 350B for the log arch and winch (working in the woods). Decided last weekend to pop some small stumps but ran into issues. Everything seems to work as it should (reverser, transmission) but then I went to push on a stump the dozer seemed to just stop. Motor did not act as though under a load. Seems to move dirt OK but compared to my other dozer, I am used to putting in 1st gear, full throttle, and the dozer either moves what it is pushing or turns the track (to a point at which the motor will nearly stall out under load). The JD just stops but motor does not even act as though it is under a load. Could this be my reverser? Not a mechanic but fortunately have a couple friends who are. Any help would be greatly appreciated. I hope I was clear enough on this post as to what is going on. I also noticed the hydraulics are not near as strong as my other dozer. Not sure it that is tied in or not.
