Posted by Bobg3204 on April 14, 2014 at 08:28:13 from (69.71.1.1):
I am doing a service on my 350 and it has a reverser lever on the left side of the instrument cluster opposite the throttle lever. There are two dipsticks on the floor and I assume the front is for the reverser and the rear is for the trans gears. I am wondering what fluids to use in both boxes. I was told that Tractor Hydraulic Transmission fluid will work. The fluid says it meets; JD J20A, J14B, (303) and J14C requirements. I would like to be sure before replacing the fluids. I am also changing all filters. I change the engine filters and oil on a regular basis - but the others I have not attempted. I assume the hydraulic filter is located in the hyd. tank on the right side and gear box filter is located on the right bottom side of the transmission behind a plate with 4 bolts. This year I noticed the trans oil (back dipstick) had turned milky white from water. I intend to let it drain for a few days before putting the filter and fluid back in. Should I flush the box with something like diesel then let it sit to drain?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
