Posted by jdemaris on April 14, 2014 at 17:53:16 from (70.194.4.4):
In Reply to: JD 350 Loader posted by Bobg3204 on April 14, 2014 at 08:28:13:
You can use combo trans/hydraulic oil in the trans and reverser as long at it meets Deere HyGuard specs. I would NOT use 303 oil in the reverser. 303 is an old standard and Hyguard specs call for more and different additives. That reverser needs all the help it can get. VERY expensive to fix. The hydraulic tank can use "hydraulic oil" or "hydraulic/trans combo oil." Note that the hydraulic system has two filters, not just one. The filter that comes off with the top cover of the tank is the hydraulic return filter (if it's even still there). Often they are put back on wrong, fall off and land in the bottom of the tank. The reason why they fall of is . . there is supposed to be a long steel dowel inside the filter that allows you to install the long 3/8" bolt good and tight without crushing the filter. That dowel often gets lost. Then the bolt cannot be tightened very much before the filter gets crushed. If your filter is actually still on - you'll see the restriction indicator bounce up and down every time you start the machine. It will stop when the oil gets warm. If you never see it move - there's likely no filter in there at all. Note: At the bottom of the tank, under the oil is a the steel-mesh hydraulic suction filter. It's often half-plugged because it gets missed. Many owners do not even know it's there. Has spring loaded clips to take out. It's reusable. Just clean it. Often full of old hydraulic cylinder packings. Besides the reverser oil, and trans oil, you also have to check and add oil to two separate final drive housings via pipe plugs. 90W gear oil is usually used.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
