Thomas, once you get the valve cover off, check that the starting valve is closing on the bad cylinder. If that valve does not seal when you switch to diesel, you will probably get the symptoms you are seeing. If it runs without a miss on gas, then it probably is not the exhaust valve. If valve(s) look OK, then it's probably the injector. Al
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
