350 and 350B have NO oil in the steering clutches. The lever has to be adjusted so as you pull it back - the steering clutch disengages BEFORE the steering-brake grabs. Sounds like you've got your brake on while the clutch is still trying to power it. When all is right - you should be able to put the crawler on a steep hill facing up - put it in forward, let the levers go - and then as you are moving forward- you should be able to pull them back to a point the crawler will roll backwards. Pull back a little more and it will stop thanks to the brakes.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
