Several things can caused one clutch pack to drag. If the plates are warped - it will always drag. If any pressure oil is getting to them - it will also drag. Lack of that 20 PSI "lube" pressure can cause much bigger problems.
One question. When you had it apart did you check the lube-oil jet that is screwed into the front of the main output shaft? If it was plugged or damaged - it will cause BIG problems. Often that center bearing assembly will melt or sieze. That is the weakest link in the reverser. Later reversers got larger updated center-bearings. If that bearing is damaged - it will also result in the machine working very hard when in hydraulic reverse. Maybe you were very careful. But most reverser failures I've seen after a rebuild - were caused by a bad oil-jet in that shaft and/or center-bearings ruined because they were not adjusted properly. You cannot adjust them by "feel" like wobbling the front shaft. The reverser must be upside down and end-play at the rear shaft checked with a dial-indicator. Put it a .002" to .004" and it will be good. Do not try to get the front shaft tight enough so it doesn't wobble.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
