When I slacken the -16 hose connections between the Variable Displacement Pump and the Hydraulic Motor, there's oil all over the place coming out, but the flow rate does not seem to change with control inputs.
My pump has also an internal Charge Pump that is producing about 120 psi that I measured the "M3" port. From there it goes thru a orifice and on to the Manual Control Valve. It then, depending on the valve position, exits via one of two paths and on to the Servo at the Variable Displacement Pump. One path move moves the Servo (& swash plate) one way while the other path drains; & vice versa.
I measured the pressures at the "M4" and "M5" ports, which are the two paths to the Servo. NO PRESSURE in either one; just a little dribble out.
So I now suspect a plugged orifice, or that the Manual Control Valve is not letting the oil thru to the Servo. The 1/8 NPT plug over the orifice is stucker that stuck so I'm working up the courage to open up the MC Valve.
I don't understand the connection of all this to my motor repair.
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series).
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
