WoodTick 1840
New User
CASE 1840 - I'm re-installing one hydraulic motor after it was repaired. All hooked up and it won't turn the axles on that side. I'm GUESSING that the air needs to be bled from the oil.
So far, to bleed it I have:
1) removed one of the 1/8 pipe thread plugs from top of hydrostatic pump, waited 12 hours to get air out, put plug back.
2) loosen sensor at top of hydraulic filter, pull wire off fuel solenoid, crank engine with starter motor to purge air at sensor, tighten sensor.
I would really appreciate some tips on this before I make it worse.
Thanks,
Thanks,
