Posted by ricnky on April 18, 2013 at 17:26:50 from (74.214.183.248):
could someone please help me? i bought a 74 model 580b with 1400 auctual hours, it had not been started for 2 years, fired right up runs great problem is no steering.. sent steering pump to hyd. rebuild shop they said it had been run dry of oil and beyond repair found a used one put it on now it will barley steer with front wheels off the ground. can or should the releif valve inside the resevoir be adjusted? if so where do i start or should i send it to repair shop for proper setting? doesen't seem to be mush pressure when i disconnect any line at cylinder or spool. anything else i need to do or check?
thanks in advance i'm new here great fourm with lots of help
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
