Crawlers, Dozers, Loaders & Backhoes Discussion Board
case 450c high low range
Posted by mthies on April 10, 2013 at 17:19:56 from (67.246.191.112):
Is anyone familiar with these machines . I just picked one up and cant figure out how to work the manual high low range . I will shift when not running but if I try to shift while running it will grind the gears . It seems like there should be a clutch some where in order to shift from high to low gear.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
