If you can bleed a 3204 quickly, it didn't need bled. I've probably cleaned that damn screen 300 times in the last 20 years. I'm not saying you don't have a frozen line but usually a line freezes solid. When the screen plugs up the engine gets the staggers and if you keep pushing it will usually quit after about a minute. If you let it idle it will sometimes recover. Most generally, if you don't run it till it quits you just shut the tank valve off, clean the screen, open the tank valve and restart. Very seldom it needs to be bled. Sometimes a couple huffs on the ether button is needed to make it run.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
