Anonymous-0
I went out to clear some snow with my 931B and it was acting like it was missing. It started and ran good for about 1/2 an hour then started running rough and had no power. After a couple minutes it would clear up and run good again for a little while. It wouldn't rev up enough to move and eventually quit where I had to loosen the injector lines to bleed it. I took the filter off to see if it had water or ice but it looked OK. I put some fuel conditioner in the tank and the filter. Got it going again and it was good for about 15 minutes then acted up again where I had to bleed it. I'm going to change the filter but have never a problem like this before. Any idea's what's wrong? It was about 5 deg's. Celcius out so above freezing.
