Each line fitting has an O ring to seal in top of housing bore that can fail over time. If the screw clamps can be removed and pump top area thoroughly cleaned each delivery valve fitting can be removed to replace the O ring. There is a spring inside too, and some have a peg in top of spring, also a brass washer on valve top that seals to fitting inside. You will need the pump assembly ten digit # to get the right O rings, for example, 123456-1234 on pump tag. Probably a PES A or AD model pump, each use different seals. Not common for so many to leak at once, but does happen. You will need the proper torque spec too.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
