I made my own track press, a short piece of H- beam with a base welded on one end and wing with a piece of pipe on the other end for the pin to pass through, my 30 ton jack works laying down to provide the force. Also made a cap with a piece of shaft for the jack to push the pin. Sometimes heat is still needed. Some hydraulic jacks only work laying down if the pump is on the bottom. I think I was able to use this on the idler sliding the wing end between pads so didn't have to remove any pads. Good luck
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
