Posted by Cameron Lee on January 03, 2013 at 04:51:43 from (99.182.40.9):
The track adjuster seals went out on my right hand track. I am trying to find out which pin is the master pin. All the pins have a bump on them, therefore; making it hard for me to know which one is the master. Can someone please offer some insight.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
Looking 4 set 9 bolt hubs 3 1/8 inch to fit 60 to 4010 jd
[More Ads]
