i have a case 310-c and was on a side hill and hit a stump , i bent the threaded rod that was used to adjust the track , my question is whats the best way to fix this and it looks like its been welded on and a poor job of fixin it the right way , (i"ll attach pictures )the threaded rod was turned down on the end to fit inside a nut that was weled on the end cap that covers the spring(i want to replace the nut on that end cap or make a new one ?) , is that cap supposed to turn and if so can i remove it ? or do i need to remove the whole track assembly , darn im lost to the best way to fix this thing , and also the long rod that go"s thru the cover and spring , what does that hold and can it be turned to remove the cap that the adjusting bolt was in ?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
