| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: case 310-c track adjuster
[Return to Forum]
| Author |
[Modern View]
| reg_rig
11-19-2012 19:08:47
50.51.47.60
i need to see a exploded view of a track adjuster , i bent the boltand cannot adjust the track any more , i need someone to give advice on to replace the threaded rod that pushes on the front idler / castor / sprocket |
| dcz3
11-24-2012 16:43:54
166.181.3.177
Re: case 310-c track adjuster in reply to reg_rig, 11-19-2012 19:08:47
| I had a similar problem I asked it it was possible to put a Hydraulic aduster in its place, use same wishbone on the idler wheel, but no one had the answer. Bought new bolt and nnut fom Zimmermans in Versalles Mo had what I needed. |
| reg_rig123
11-21-2012 06:19:35
50.51.62.166
| i have a case 310-c and was on a side hill and hit a stump , i bent the threaded rod that was used to adjust the track , my question is whats the best way to fix this and it looks like its been welded on and a poor job of fixin it the right way , (i"ll attach pictures )the threaded rod was turned down on the end to fit inside a nut that was weled on the end cap that covers the spring(i want to replace the nut on that end cap or make a new one ?) , is that cap supposed to turn and if so can i remove it ? or do i need to remove the whole track assembly , darn im lost to the best way to fix this thing , and also the long rod that go"s thru the cover and spring , what does that hold and can it be turned to remove the cap that the adjusting bolt was in ? |
| reg_rig123
11-21-2012 10:40:36
50.51.47.112
Re: case 310-c track adjuster in reply to reg_rig123, 11-21-2012 06:19:35
| i put that post in , cause i didnt know how to start a fresh one , please if anyone can help me with the track adjuster issue it would be greatly appericated |
| LJD
11-20-2012 09:43:31
75.213.82.178
| | Adusters at this place are $62 each. You might find cheaper if you shop around. http://www.epsstore.com/index.php/d20843.html If the threads on the big long bolt are bad - yon can get new bolt for $77 or make a new one from grade 8, 1" threaded rod. |
| LJD
11-20-2012 05:01:19
75.213.82.178
| You can buy new aftermarket mechanical adjusters almost as cheap as you can make them. I bought two this past summer for my 310G. If the female threads are stripped you can weld in new steel nuts to fix. |
| urbancase
11-20-2012 01:38:12
65.196.192.2
| i had one years ago, i replaced mine with hard threaded rod 1 inch fine, i made 2 new nuts to fit in the coller of the bracket that goes around the front idle wheel. it solved my problem with the tracks coming off, it looks worse than it is to fix. i got the threaded rod from mcmaster-carr. |
| Mo 1032D
11-19-2012 19:19:50
216.145.149.118
| You might try going to CNH website, go to construction equipment. I looked up parts on my 310-g, was some good exploded views you can enlarge. Helps if you have serial #, breakdown for parts list was serial number breaks. Scott |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
