Your idler is probably runing outof line. the shims under the side plates can correct this. cut a 2 or 3 inch hole on the side of the idler then weld up the crack and then add on to the center until it is back to center and add passes to both sides until it is back to the original diameter. I have did many cat idlers on the machine, break the track and run the idler out past the end ofg the track. I did a set n a 973 about 6 months ago. a magnatic ground helps you an turn the idler without having to unhook the ground clamp
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
