Most guys have never seen a 3/16" rod, and don't have a power supply with nearly enought amps to burn one. That being the case, a couple of passes with a 1/8" 7018 more than likely won't build as much heat as one pass with the much larger rod. That said, yeah, I know what your saying but my thoughts were that a hole cut and then welded back up by some one that doesn't do alot of cutting and welding would tend to be more of a problem (read new crack waiting to happen) than just not worrying about it. If it were me I'd much rather drill a small hole. In this case 1/4" diameter should be a gracious plenty as a vent, and much easier to weld up than a plate cut out of the side. Too a small hole is far less likely to propulgate a crack due to the round shape than a torch cut hole.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
