Restoration & Repair Tips Board
Re: Grandpa’s Seized Farmall H
ss55
10-06-2017 21:14:55
You might want to ask around as to why the tractor was parked under a tree 25 years ago. There may have been one or more major problems with it way back then. Besides stuck pistons and stuck valves, odds are very high that the piston rings are stuck to the pistons, so they won't seal very well and will allow a lot of blowby. That may be OK for parade duty and occasional use for a while. If you are planning to make it a working tractor again, plan to pull the engine apart.
