Re: Planter questions
Paul
04-02-2013 19:18:25
Welding seems to be a waste.
Adjusting the transmission - the gears - is the right way. Typically there are 2 places to change speeds, and you get a lot of possibilities. Have you worked that all out?
Otherwise, I'd use putty or epoxy or some such to fill every other hole, can burn the junk out again when you find out that's not the right way to do this. ;)
Paul
