Re: Oh 1460 hydro won’t move
Dave H (MI)
12-16-2017 14:21:32
Have you isolated this to propulsion only? Does the header go up for example?
joshbraman
12-16-2017 14:43:41
 Re: Oh 1460 hydro won’t move in reply to Dave H (MI), 12-16-2017 14:21:32
Yes all hydraulics work except propulsion
joshbraman
12-17-2017 04:15:20
 Re: Oh 1460 hydro won’t move in reply to joshbraman, 12-16-2017 14:43:41
I guess it’s possible that the transmission went but it’s odd it just stopped moving. Yes I checked the couplers on the drive shafts. The hydro motor seems to not be turning. I’m chasing fluid and filter in it this week and trying the air bleed procedure otherwise it’s baffling. There was no indication of cavitation withthe hydro pump. It’s like the hydro drive motor just quit working. Will they just fail? Is there a relieve valve or bypass valve I need to be checking?
DWinMI
12-17-2017 15:57:11
 Re: Oh 1460 hydro won’t move in reply to joshbraman, 12-17-2017 04:15:20
There are a few values in the system need to be sure they are working correctly. If you got drawing for you system would help out greatly. Is your charge pump working for the system that would be an easy fix. Good luck
