Joshbraman
Our 1460 combine just quit driving. I heard a growl noise and it stopped. I?ve have checked the splined shaft on the hydro pump to make sure it?s turning. We replaced that shaft 3 yrs ago because the seal was leaking on the pump. I checked to make sure the cable was moving from the forward reverse lever. When you move the lever ahead then try to shift into gear there is no grinding. I did accidentally add some iso 46 fluid. I talked to the dealership and he said we were fine we only had 12 acres left to finish on corn. What am I missing or should I be ch cling I?m baffled?
