i struck oil again
bdunegan
03-30-2005 17:41:26
took dipstick off and put regular oil plug in, changed valve breather cover(disc is free), took carb off and cleaned all oil out. started up, and runs fine at idle. speed up, and oil comes out of breather tube into carb and engine smokes. take off breather tube from carb, and engine runs fine and gets rid of oil in carb.breather tube unhooked drips oil, but not bad. hook tube back to carb, and you can actually see it pulling oil to carb. not ohv engine, but could it still be the head gasket blown, or something wrong with valves?
JT
03-31-2005 18:34:21
 Re: i struck oil again in reply to bdunegan, 03-30-2005 17:41:26
did not see that you posted it had been stuck before, you need to take off head and see what is up, you might have a bad score in cylinder, allowing compression to bypass and that is allowing the crankcase to presurize and then this is the end result.
JT
03-31-2005 18:31:44
about the only other thing I could think of is you may have valve guides worn and valves are sloppy loose. It would need new guide bushings to fix that. If this has been sitting for very long, you could also have rings stuck enough you are getting blow by, not very likely this is it, but it is a possibility.
