TractorLinks.com
Re: Atlas Walk behind snowblower
Jim
09-08-2000 13:46:21
I have an Atlas Snow Thrower(blower) Model SN420A
I have the owners manual with parts list. The assembly istructions. The engine operating and maintenance instructions for Briggs and Stratton models: 100200 to 100292 130200 to 130292
Jim
Herb
12-20-2003 17:40:16
 Re: Re: Atlas Walk behind snowblower in reply to Jim, 09-08-2000 13:46:21
Sorry can't help you. I am looking for a source of parts for an Atlas 15-5211A snow thrower, particularly the clutch spring. I think this is a newer model (only about 20-25 yrs old!). At some point I was advised that another company had bought Atlas' stock of parts, but I can't find that reference. I have 3 of these snow throwers in the hope of having parts, but clutch springs are gone on 2 of them. I can't believe parts were made JUST for this machine--does anyone have any ideas?
Herb
Jerry4245
01-07-2008 10:13:33
 Re: Re: Re: Atlas Walk behind snowblower in reply to Herb, 12-20-2003 17:40:16
My friend and I both have an atlas #15-5211 we both replaced the clutch springs in 1991. His just broke again. MTD bought out ATLAS. You can get a spring from MTD or jackssmallengines.com You might have somebody close who sells MTD. The part# they use to replace it is 707893 and it sells between 30 & 40 dollars.
Dan
03-23-2004 14:37:34
You might try www.hanceco.com. I have bought parts from them before.
Anyone have a copy of the manual for the 15-8261A model snow thrower. This is a two stage unit with an 8 hp motor. I would love to get a copy of the manual.
Dan
Anthony
01-16-2004 09:15:26
I am also looking for a spring for this machine. If you are successful finding them please advise. I will do the same.
Herb
01-16-2004 18:47:06
 Re: Re: Re: Re: Atlas Walk behind snowblower in reply to Anthony, 01-16-2004 09:15:26
Anthony<
The only two approaches I can think of are: 1. have someone make a few for us, but the cost may be high; and 2. try to see if any of the old repair shops have some lying around.
Herb
Andy Smith
12-06-2003 10:51:27
I also have an atlas snowblower, runs well, but my drive way has a slight incline, that causes it to shut off. anyone have a solution. btw it is a 4hp briggs, single stage, 20", pull start, model SN420A, serial # NI 1909, anyone have any info? please email me.
Andy Smith
12-06-2003 10:43:09
Ira
11-25-2002 19:39:06
What size tires does this machine have ? I have one and there are no markings on the sidewall of the tires to indicate the size.
The tires measure 9" o.d. x 5.75 " i.d x 2.75 " wide. I would like to put chains on for better
traction.
MURRAY BLIGHT
11-23-2002 14:09:23
I HAVE THE EXACT SAME MODEL SNOWBLOWER AND AM LOOKING FOR THE BRASS GEAR THAT IS IN THE FRONT IMPELLER HOUSING AS MINE IS MISSING MOST OF ITS TEETH. THIS GEAR IS THE ONLY BRASS ONE AND IS APPROX 3/4" INSIDE AND ABOUT 2" OUTSIDE. ANY INFO WOULD BE APPRECIATED.
William O.Carter
09-20-2002 08:48:47
I have an Atlas Snowblower,Model:15-5211,Serial#: E006655 with a 5hp Briggs engine. I'm looking for an operations manual.If anyone can help me out I would appreciate it. It was manufactured by Atlas Tool and MFg.Co in St.Louis,Mo. I saw where this company no longer is in business.
Dave Pray
02-19-2003 13:15:17
 Re: Re: Re: Atlas Walk behind snowblower in reply to William O.Carter, 09-20-2002 08:48:47
I have an Atlas Walk behind snowblower, model 60-3218. I don't have an owners manual. Can anyone help me?
walt
09-26-2003 15:49:56
 Re: Re: Re: Re: Atlas Walk behind snowblower in reply to Dave Pray, 02-19-2003 13:15:17
Note: I have a Atlas snow thrower 2-cycle model 15-3220 serial #F-003076. I'm in need of information where to run two wires that came loose. One is a Green wire coming from the magnito I think, and the other one is a ground to the chassie . Please answer as soon as possible. Thanks in advance.
Rick Studer
02-24-2003 09:37:26
I have an owners manual for a model 15-5211A. I don't know if that would do you any good, but would be happy to get you a copy if you want one. But I also have a question. I need a wheel. Do you have any idea where I can get one, or any where that has service parts for older Atlas snowblowers?
James Sullivan
01-03-2004 17:14:25
 Re: Re: Re: Re: Re: Atlas Walk behind snowblower in reply to Rick Studer, 02-24-2003 09:37:26
Hello i also have an atlas snowblower but i have no model# or anything, do you think i could get a copy of your manual, maybe i'll get lucky and it will be the right model. thanks.
Stan
12-29-2002 12:51:07
I HAVE THE IDENTICAL SNOWBLOWER. I ALSO HAVE THE OWNERS MANUAL. IT IS ONLY 8 PAGES. I COULD PHOTOCOPY IT AND MAIL IT TO YOU.
Mary Hankins
01-29-2004 13:59:52
 Re: Re: Re: Re: Atlas Walk behind snowblower in reply to Stan, 12-29-2002 12:51:07
The wheel that is turned by the drive belt snapped in half on my Atlas Snowblower--
model #A520ES-N
Service #--603241 (5hp--20in.)
I tried a simple glue job to no avail.
Where can I find a replacement? Someone said that Atlas was out of business. Are there parts to buy? Did someone buy them out? Mary
Chris
02-03-2004 11:13:14
 Re: Re: Re: Re: Re: Atlas Walk behind snowblower in reply to Mary Hankins, 01-29-2004 13:59:52
Mary - I've been looking for parts for mine as well.
MTD -- www.mtdproducts.com seems to be the only place that handles Atlas anymore.
Their number is 1-800-269-6215, and they sent me to the 'archives' dept for info on my Atlas, which is 1-800-800-7310.
good luck -
Chris
Monte Scrivens
02-05-2004 18:41:14
 Re: Re: Re: Re: Re: Re: Atlas Walk behind snowblow in reply to Chris, 02-03-2004 11:13:14
I have a 15-5220 Atlas. need some parts and/or manual for part #'s. Machine is also for sale if I cant get parts, someone else can have it. It currently runs, but I would like to fix it up a bit.
