Order Ford 2600 Parts Online
Re: 2600 instrument power
soundguy
09-22-2015 11:15:48
third party image
here is a pic of the online service parts breakdown. look at #4 that's the location of the vreg.. see that plug/connector there.. that's the plug in for the harness that connects to the dash cluster. I think the fuse is closer to the cluster. if so.. then that connector may be the issue / stoppage.
RickB
09-22-2015 17:17:35
 Re: 2600 instrument power in reply to soundguy, 09-22-2015 11:15:48
I'm all but certain the proofmeter cluster power goes from the key switch to the fuse and cluster without going back to the main/rear main harness connector SG is calling out.
Not enough conductors in that connector to carry that circuit, and no reason to go there.
soundguy
09-23-2015 04:53:48
 Re: 2600 instrument power in reply to RickB, 09-22-2015 17:17:35
on second look.. I see now that the wire while likely in the harness, is in a stub, upstream from the connector.. and for sure agree no reason to route it down and back vs just from the stub to main.
soundguy
09-23-2015 04:50:39
wiring 'picture' ont he parts site wasn't too descriptive. so I was thinking it might be a possibility if it was in the harness. If not, it shouldn't be hard to trace from switch to fuse.
