Order Ford 2600 Parts Online
Re: 2600 instrument power
soundguy
09-22-2015 11:01:17
yes.. high density connector.
On that model it should be located , breaking the wiring harness right near the voltage regulator... IMHO.. that is before the fuse.. thus there may be a bad connection at the connector.
GreenAcre
09-22-2015 18:53:12
 Re: 2600 instrument power in reply to soundguy, 09-22-2015 11:01:17
Ok thanks will check there. Its all still wrapped up original will look for it there..
soundguy
09-23-2015 04:53:37
 Re: 2600 instrument power in reply to GreenAcre, 09-22-2015 18:53:12
On second look at the harness, I think Rick is correct. look for a stub harness connection fromt he key over to the cluster.. should be a short run. that will be ahead and not involve that connector.
might be something you can razor blade open and check.
if you have power at the key connection, but not at the fuse, there is only a few inches of wire inbetween.
GreenAcre
09-22-2015 11:10:20
soundguy
09-22-2015 11:15:48
 Re: 2600 instrument power in reply to GreenAcre, 09-22-2015 11:10:20
third party image
here is a pic of the online service parts breakdown. look at #4 that's the location of the vreg.. see that plug/connector there.. that's the plug in for the harness that connects to the dash cluster. I think the fuse is closer to the cluster. if so.. then that connector may be the issue / stoppage.
RickB
09-22-2015 17:17:35
 Re: 2600 instrument power in reply to soundguy, 09-22-2015 11:15:48
I'm all but certain the proofmeter cluster power goes from the key switch to the fuse and cluster without going back to the main/rear main harness connector SG is calling out.
Not enough conductors in that connector to carry that circuit, and no reason to go there.
soundguy
09-23-2015 04:53:48
 Re: 2600 instrument power in reply to RickB, 09-22-2015 17:17:35
on second look.. I see now that the wire while likely in the harness, is in a stub, upstream from the connector.. and for sure agree no reason to route it down and back vs just from the stub to main.
soundguy
09-23-2015 04:50:39
wiring 'picture' ont he parts site wasn't too descriptive. so I was thinking it might be a possibility if it was in the harness. If not, it shouldn't be hard to trace from switch to fuse.
