Re: Farmall 560 Gas engine won’t start
gabsgrammy
07-01-2018 08:37:13
The governor spring and pivot pin seem to be fine and I made sure to grease them. As I mentioned the linkage from governor to carburetor will not engage when the tractor is running but if the engine is off and then throttle is pulled all the way open, the spring, pivot pin, and linkage move like they should. When the engine is on and the throttle is pulled open, the linkage from the throttle to the governor engages but not the linkage from the governor to the carburetor. Nothing appears to be rusted or seized up.
rustred
07-02-2018 05:32:46
 Re: Farmall 560 Gas engine won’t start in reply to gabsgrammy, 07-01-2018 08:37:13
appears like you have a governor problem.
