gabsgrammy
Farmall 560 gas governor to carburetor linkage- I have an issue with my farmall 560 gas. When the throttle is pulled all the way open the linkage from the lever to the Governor retracts the spring as it's supposed to but the linkage from the Governor to the carburetor won't engage unless I move it by hand after opening the throttle. When the tractor is not running however and I open the throttle, the linkage works properly and engages the carburetor. So when the tractor is running the linkage from the Governor to the carburetor does engage but when the tractor is off the linkage moves like it should. What needs to be adjusted? I inspected the inside of the carburetor and the float needle, gasket, and everything else is fine. Any help would be appreciated, please and thank you.
